Adjust Rec Levels on the Fly
spg66
Will the new Sony Hi-MD units allow the recording levels to be adjusted on the fly without having to drill down through a set of menu options to enable it (i.e. when using the line input will you be automatically able to adjust the levels as you are with Sharp units)?
Is there any news as to when Sharp will be coming out with a Hi-MD unit?
